Make sure the cartridge is genuine. If yes, uninstall and reinstall the pc unit and the toner cartridge. If you get the same error a firmware fix may resolve the problem. Please contact Lexmark Technical Support for further assistance.
Though Lexmark does not recommend using refilled ink cartridges, you may try to refer to this article in the Lexmark website on Unsupported Cartridge Error on a Lexmark X3330/X3350 All-In-Oneto determine and resolve the problem. If error continues, try to insert a different known working cartridge. Thanks.
If this is a genuine Lexmark device and a genuine Lexmark cartridge and you followed all the install instructions, return it to where you bought it for a replacement. If you get grief there, contact Lexmark directly. Please have your receipt available when you take these actions.
The Lexmark x340 and x342n has 3 sensors that identify the path of the paper below it. 2 are below the feeder roll of paper and the other in fusion. Clean the sensor or adjust the tamnho the paper tray to which the document is.
Remove the jammed paper by gently pulling it straight out of the MFp Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
What is happening is that a paper sensor is either hung or jamed so that the sensor is incorectly reporting an error .
I would remove the cartridge and using a flash light search for any scrap of paper that may be in the paper path. If you can't find any, I would next looked for a sensor flag to see if it is jammed out of position.
Of course, you could always call a service tech or even better submit this question to Lexmark Technical Support for more in depth assistance.
1. try to reinstall cartideg and check.
2. check printer with new cartirdeg or check your printer cartidge in any other printer .
your cartidge may by faulty 90%
3.now the problem in your printer sencer so do service of your printer if u can.
