Toys Logo
Posted on Jul 16, 2011
Instructions as to HOW TO PLAY DRAUGHTS - Toys
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
224
Points
8
  • Set up your pieces on a black-and-white checkered game board with 64 squares of each color. Each player should set their 12 pieces on the 12 black squares closest to them on opposite sides of the game board.Decide who goes first by tossing a coin.Move a game piece forward diagonally along the black squares if you are the first player. You may move only one square at a time per turn and you must go forward on the board.
  • Take your opponent's game piece by jumping over it forward diagonally along the black squares if your opponent has one of his game pieces adjacent to yours and there is a vacant space beyond your opponent's piece. You may take more than one jump if you land on a space where you are able to jump another of your opponent's game pieces
  • Have a game piece crowned as a "king" if you reach the far edge of the board closest to your opponent. Your opponent must place one of the game pieces he has captured from you on top of your king piece to distinguish it from your other pieces. Your king is now allowed to move diagonally forward or backward instead of just forward.Win the game by capturing all of your opponent's game pieces,Hope this helps :D
  • Add Your Answer
    1helpful
    Where can I find instructions on how to play the game Got You by Murfett Pty Ltd
    see this link for video instuctions:https://www.bing.com/videos/search?q=instructions+to+play+got+you+murfett+party&qpvt=instructions+to+play+got+you+murfett+party&FORM=VDRE How Do You Play Games
    tip
    What if I fail my dissertation?
    If you don't have a thesis, you are often able to submit it again by the specified deadline. Just like with a module failure, the marks for a re-submitted thesis are typically limited to the minimum level. It should also be noted that a thesis failure is unusual in the UK and usually occurs only when a student has forgotten to contact their supervisor at regular intervals or neglected to submit draughts before the final submission.
    Each institution has its own procedures for appeals from university students and needs a very extensive process in general. Before the deadlines, you must be assured that you have submitted the necessary documents and that the reasons for appealing your grades are well documented. There are many British Dissertations Help services available online which can help you in all aspects.
    Why dose 45side draughts when warm up run faster an will not idle
    WHAT DOES AN ENGINE HAVE TO DO WITH CHECKERS???
    Draughts (/?dr??fts/, British English) or checkers[1] (American English) is a group of strategyboard games for two players which involve diagonalmoves of uniform game pieces and mandatory captures by jumping over opponent pieces. Draughts developed from alquerque.[2] The name derives from the verb to draw or to move.[3]
    What are the rules of Backgamon?
    Backgammon playing pieces are known variously as checkers, draughts, stones, men, counters, pawns, discs, or chips.
    The objective is to remove (bear off) all of one's own checkers from the board before one's opponent can do the same. The checkers are scattered at first and may be blocked or hit by the opponent. As the playing time for each individual game is short, it is often played in matches, where victory is awarded to the first player to reach a certain number of points.
    Jan 17, 2013 • Games
    3helpful
    No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
    I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
    So to put it up.....
    lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
    Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
    Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
    These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
    Enjoy
    Weston fish and chip 3 pan fryer cuts out often in wind have you any solution. ( its not lack of gas).
    check the terminal on the flue it may have fallen off as you are getting down draughts
    1helpful
    2inch gaps around bottom of tent when pitched causing draughts
    Are you talking about the gaps around the fly? Or the actual tent? There is a reason the flys do not go all the way to the ground, if they did they could wick moisture off the ground and leave you wet and cold!!
    Top Toys Experts
    ADMIN Andrew
    ADMIN Andrew
    john h
    Are you a Toy Expert? Answer questions, earn points and help others
