Nokia 6030 Cellular Phone Logo
Posted on Jul 16, 2011
I have NOKIA 6030 ; IMEI NO. 355542/01/48221511. My phone book memory is locked, asking for security code. I am entering 12345, but it is giving security code error. Please help
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
271
Points
6
If your mobile is locked with security code then try to reset it with master reset codes from unlock-free and for Locked contacts try to go to near by service center to get rid of your problem..
2answers
Phone restricted,
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
6helpful
4answers
Security code for nokia 1650
n1650 v4.11
10-11-07
rm-305(c)nmp
imei
352051024314087
Nokia 6030
hey enter this code when it ask for security code............ the code is ' 2011427371
1helpful
2answers
SECURITY CODE NOKIA 6030
What is your 15 digit IMEI number?
Security code
My phone nokia 6030 required security code. I have tried 12345 but failed to get excess into it. Appreciate someone to help me.
My IMEI number ;011125/00/631054/6
Restriction code for nokia 6300 locked in fido
The security code, if you did not change it is mentioned in the user manual book. For Nokia cell phone, it is usually 12345.
This is the code the phone asked you to enter when you change your SIM card.
The code only asked once for every SIM card, unless you reset your phone. To disable this code, enter menu settings, Security, Security Level, change it to memory or none. To change this you need the security code.
2answers
Secutity code NOKIA 6030
Hi, I can give you the master code for your phone ok but need to tell you some info first.
The code only works if the phone asks for the code when you switch it on ok
Also the code wont work if the wrong number has been tried more than 5 times ok so if you have tried 5 wrong guesses then the phone is hardlocked and can only be unlocked with lead and unlocking software ok
Here is your master code ok 5240411365
4answers
Security Code Nokia 6030 Type RM-74
Hi i can help you as long as your phone is asking for the code as soon as you switch it on if not then the master code wont work its only if the phone is asking for the code when its switched on.
It also wont work if the wrong code has been entered more than 5 times ok
your master code for you phone and imei number is 1072517604 enter this when asked once the phone has powered up ok.
If this isnt the code you need and you want to change the security code on the phone then to find out what the security code is is by buying flash lead and unlocking software the code i gave you only works if its asked when the phone is first switched on also the code resets the security code to what it was when phone was new usually 12345 or 1234 or 0000 depending on the original network that the phone was on.
Let me know if you need further assistance
My phone memory locked
This is the master code for IMEI 353938019436975:
To use this mastercode, you have to input the wrong security code untill the phone request the master code, then
leave the phone off for about 10 minutes, start the phone, and go to the menu Tools/ Settings/Security/ and input this code in:
5266173511 this master code is calculated for your IMEI only.
What is my 6030 security code
hi if the phone is asking for the security code when you switch phone on then i can give you master code but this only works if phone ask for code as soon as its switched on also this code wont work if you have entered the code wrong five times here is the code for your imei number i have all ready sent you the code in previous post let me know if you got it and ill give it you again if not
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
