Question about HEWLETT-PACKARD Computers & Internet
I assume the 2760's screen rotation works the same as the 2740. If so, I ask how does one rotate the screen? I can get myself into OneNote and can write successfully with the pen, but I cannot change the orientation of the display. I know that I saw the display rotated on one occasion, but I don't know what got me there. Pressing the button on the back of the machine does nothing, and the Control Panel is of no help because I don't know what the HP default sequence is. And the display never changes anyway.
Posted by Charlotte Chell on
Larry Ng
  • HEWLETT-PACKARD Master
  • 5,969 Answers
What is a 2760,
my wild guess is its there, RTM, read the manual yet>
https://support.hp.com/us-en/product/hp-elitebook-2760p-tablet-pc/5071191/manuals
Posted on May 13, 2017
1 Related Answer
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: Screen Won't rotate
you need to change your screen resolution to rotate, make it so that it is taller rather tan wider
Posted on Dec 27, 2009
Screen will not rotate
Check your configuration, go to settings, and search for a screen/display option, there you can change an option of auto rotation, every android and apple device has it i believe.
May 09, 2016 | Tablets & eReaders
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
Jan 17, 2016 | Tablets & eReaders
The plastic gear that rotate the bobin housing rotation was broken, how can I order it that part(hobby 541), I don,t know that part name.
I'd call it a bobbin drive gear, but your best bet is to look for a parts list for your machine. These usually have diagrams and tables that give the manufacturer's part numbers.
Jan 03, 2015 | Sewing Machines
Hotpoint dryer belt
You can do it yourself if competent at diy but you need to slide the belt over the drum by releasing one end of the drum.
Dec 12, 2013 | Dryers
Why does the screen keep rolling in circles
I'm assuming it rotates 90 degrees at each 'roll'? Try cleaning the keyboard. Usually a combination of CTRL and another key is the shortcut for rotating displays, and some of your keys might be sticking.
Jun 13, 2013 | Computers & Internet
I want to rotate the screen on my HTC touch VIVA, is there any software or any settings i can change, if software where do i find it
My Hermes allows me to rotate the screen using a hardware button assignment or using the HTC Home plugin. Using a 'touchflo'-like application -with no hardware button to spare- it was annoying going back to my today-screen to rotate the screen.
It turned out the Compact Framework 2.0 has this nice class which would do the trick: Microsoft.WindowsCE.Forms.SystemSettings.ScreenOri entation
So I "wrote" exactly 10 lines of code (including class/function def) to rotate my screen.
Anyone interested: download and install the cab.
+ Does not remain in memory: rotates the screen and exits
+ Now you can create a shortcut to rotate the screen
+ tested on a Hermes (TyTN)
- Requires Compact Framework 2.0 (should be default for Windows Mobile 6.0)
- CF is a huge overhead when only needed for this program, but I'm to lazy to go for the API call (ChangeDisplaySettingsEx)
- No settings: rotates 90 degrees counter clockwise (or 90 degrees clockwise with the Rotate Screen CW cab) -on my TyTN it matches the screen setting when the keyboard slides out-
- Not tested on other hardware, but I expect the worst thing that could happen is a frozen device which will work nicely after a soft-reset. My expectation is based on the fact it's a CF 'call' and not an API call, therefore it does not write to memory locations directly.
Use 'as is'.
I might be tempted to add 'settings' if people actually would use the program and have requests...
When installed on other devices: a message would be appreciated (even if is doesn't work)
Mar 10, 2010 | HTC Touch Viva Cell Phone
Can't reverse ceiling fan rotation
some fan models will only spin one way!! If there is not a switch on the side cover of fan.
Feb 04, 2010 | Emerson CF2600PW Raphael Pewter Ceiling...
Can anyone tell me on where can i find the product key for Microsoft Office Student and Home version.and it ask for product key when i open it. then it says modification is locked
The product key is on the plastic case that Microsoft Office Student and Home came in, but not in an obvious position. The case is a strange construction. If you hold it with the front facing you, the inside rotates to your right, After you open it, turn it around. On the backside of the part that rotated is a sticker that contains the product key and a bar code that I assume is the same thing.
Jun 13, 2009 | Microsoft Office OneNote 2007 Home and...
Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Dec 22, 2007 | Samsung Q1 Tablet PC
Computers & Internet Logo
177 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
