Refrigerators Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My maytag wide by side Refrigerator was working fine and all of a sudden everything melted. Called repair man and don't know what he/she did, however the frig worked again, but for only about 2 months and now has quit cooling again. The lights and control panel all light up, but the motor won't turn on. Where should I begin?
Anonymous
Level 3:
  • Refrigerators Master 43,501 Answers
  • Posted on Jul 17, 2011
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10842730
Points
101584
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
3answers
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
My maytag wide by side keeps freezing up. I have
It's determined by how much you are in and out of the unit,the board uses the light switch to count how many times you open and close the door if the switch isn't working properly it won't defrost often.Under normal usage you should get at least 2 defrosts in 24 hours.
2helpful
2answers
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Maytag wide by side
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
1helpful
Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Maytag MSD2454 SIDE X SIDE
Hi I have had this also happen,I need have a repair man come in to fix this and was told it will NOT happen again.Surprise!! It has happened again.But I was told that thee is a plug in the freezer side that get frozened up so this time I had to take everything out of the freezer,the bottom rack,then un-screw the back panel,in the bottom there is a small hole and this is were it is freezes up.Why?? I still do not know,but once again I have a call into the repair man again.But this time I did notice were the coil sits next to the freezer wall,it has melted,as if a fire had been there,So No I am not a happy camper myself.But good luck with yours.
Whirlpool side by side not staying cool
make sure that everything is running in it - the compressor - any fans and that all airflows are ok.
If all is working then it is a refrigeration problem. low gas, blocked pipes or filter. This will have to be looked at by a refrigeration mechanic
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
