Question about Coby DVD938 Theater System
I have a Coby DVD938 dvd player. I have sound and picture but the color on the picture is only in black and white. How do I fix this?
Posted by mdogn711 on
Nate
  • Coby Expert
  • 133 Answers
Make sure the video connections are in the correct ports If they are, get to the screen with the coby logo, make sure no disk is in the tray and reset the DVD player with remote:
Make sure you do not have a disk in the tray. Using the DVD player remote control:
  1. Press 'Setup'
  2. Press the right arrow 4 times
  3. Press the down arrow 7 times
  4. Press Enter
Posted on Sep 02, 2011
sdpritchett
    New Friend:
How can i hook up my cable to my system
Posted on Mar 25, 2013
How do I hook up my coby dvd to my blu ray
There should be an orange rca plug on the back of the blue ray player. That is a digital audio output plug. The Colby has a similar plug. That's the digital audio input. It won't make any difference for the most part what color the your cable is. It could be red or white (one of your stereo plugs of need be). Connect the cable between this two plugs. Viola! (It's wise however to use orange cuz then you could easily distinguish which cable is carrying the digital audio). Make sure that digital audio is selected in your menu.
Jul 05, 2015 | Coby DVD938 Theater System
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
I have a Coby DVD938 hooked up through a cable box. The sound is fine when a DVD is playing, but when the TV plays, the sound is very quiet. I tried hooking the audio wires direct to the TV and had the...
You're Going to have continuous problems like that with your current configuration. You should plug your video and audio cables directly to a separate input into the back of you set. That's provided of course that you have another input on the set. If your set and dvd player are HDMI cable capable then you also would have typically another hdmi input. In that cast you don't need separate audio cables. The audio is carried as a digital signal in the HDMI cable.
Oct 28, 2013 | Coby DVD938 Theater System
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
I have sound from the coby938 when playing a DVD but not from my tv. I have my directv cable box, my Xbox and m ps3 connected via HDMI cables. How can I get sound out of all three and into the coby938???
Your TV would have to have an AUDIO OUTPUT port (RED/WHITE) and that would go from the back of your TV, to the RED/WHITE input on the DVD938. All your other devices would go directly to your TV. After you do that, you change the input on the DVD938 remote to AUX.
Sep 22, 2012 | Coby DVD938 Theater System
Trying to hook up coby DVD938 to tv. would like to use it for sound to hear tv through speakers even when not playing a DVD. How do I hook it up that way......
Take the red, yellow and white cord and plug it into the back of your cable box and then run it to you tv and then push the Source button on your remote on the Coby until the display says "Line" and there you have it
Sep 05, 2010 | Coby DVD938 Theater System
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Coby DVD938 Theater System Logo
343 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
