The fused burned out not because it is faulty but because a problem occurred, probably a short circuit, which resulted in the high-inrush of current. This burning out of the fuse on the motor controller module usually caused by faulty drain pump motor. Water leaks in the drain pump damages the pump motor winding and results in short circuit which eventually burns out the fuse. The drain pump must be checked first for such condition and replaced if necessary before replacing the fuse or the motor control board for that matter.
