Pioneer VSX-27TX Receiver Logo
Question about Pioneer VSX-27TX Receiver
Hi I have a Pioneer Elite VSX 27-TX receiver I've had it since 1999 never a problem. However last Sunday I turned it on and no audio, well initially I'd get a cyclic splash of static but now nothing. The display comes on and seems to function normally displaying each of the input selections either from front panel or remote. I suspect the amplifier section is out of the loop. I had been eyeballing the SC-37 for a while but it is too soon to fit it in the budget. Any good ideas other than take it to a repair shop? Thanks, John
Posted by jwill911 on
Anonymous
  • 8,546 Answers
Turn on your TV and see if it has found its way into the System Setup Menu by mistake.
Posted on Jul 16, 2011
Where can i find diagram for bad soldering for pioneer elite VSX-27TX stereo receiver?
You really should be an expert to do repairs on these recivers but if that is the case, you can get the maintenance manual here:
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-24_26_27_29_D908S_RRV2133.pdf
Pioneer VSX - 26 TX single-processor receiver elite no sound work fine one day turn on have no sound checked all the connections everything's good here clicking in the receiver can you help me
You may have overloaded your amp. If you have a separate amp in line then this would not be the case but if you are using your receive as the amp then it could be. Look for a fuse on the unit. Usually a small black square marked with 15a.
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
2answers
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
1helpful
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
I have a Pioneer Elite VSX-05. When I turn it on
check in front of your receiver and check the button wheres say mute press that button and
see if work or buy universal remote.
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
