Question about HP Color LaserJet CP4005dn Network Printer
I have a hp cp4005dn on a network. The prints have color repeating dotts . I have change the toner cartidges and transfer belt. I still have issues.
Posted by marvin_merri on
  • Mark Schmit
    Mark Schmit Jul 16, 2011
    If they are repeating dots measure the distance between them and I should be able to tell you what is wrong. Are the dots all one color?
guilopmar
  • 304 Answers
Calibrate the printer after replacing the ETB.
Full Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller, the ETB,
the drum drive motors, the drum drive gears, or a laser/scanner. Full Calibrate Now includes theQuick Calibrate routines and adds Drum Phase Calibration and Color Plane Registration. Full
Calibrate lasts for about four minutes.
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight FULL CALIBRATE NOW.
7. Press to select FULL CALIBRATE NOW. Wait for the printer to calibrate.
Posted on Jul 16, 2011
How i replace ETB for hp cp4025
Replacing the Transfer Belt (ITB, Transfer Kit) HP Color LaserJet CP4525 CM4530
1. Open the printer's right side door.
2. Use the blue lever (see callout 1 in picture below) to lower the secondary transfer assembly.
3. Grasp the small handles on the transfer belt assembly (circled in blue in picture below), and begin gently pulling the assembly out towards you, until a set of 2 larger handles pop free on the sides of the transfer belt assembly.
4. Now grasp the larger handles on the transfer belt assembly, and continue pulling the transfer belt straight out of the printer until it is completely removed.
5. Avoid touching the surface of the new transfer belt. Install in reverse order, sliding it securely into the machine.
6. After replacing the Transfer Belt, it's a good idea to perform a Full Calibration (or even several Full Calibrations in a row, if you are having print quality issues). Full Calibrations help with print quality by aligning the color tones, the drums, and the color plane. Each Full Calibration takes about 4 minutes. To perform a Full Calibration: Press MENU to enter the menus. Press Down Arrow to highlight CONFIGURE DEVICE. Press Checkmark to select CONFIGURE DEVICE. Press Down Arrow to highlight PRINT QUALITY. Press Checkmark to select PRINT QUALITY. Press Down Arrow to highlight FULL CALIBRATE NOW. Press Checkmark to select FULL CALIBRATE NOW. Wait for the printer to calibrate (usually takes 4 minutes or so), and then print a test page. If print quality still needs improvement, repeat the Calibration. If multiple Calibrations don't help, some of the toner cartridges may need replacement.
5e5fcf65-5757-40c3-a110-1a2864982d2e.jpg 554a3a0e-c038-46ec-983d-7467c3deeccf.jpg 7883eb6b-6a29-43fd-b69a-0ff825f60373.jpg bb2de9b0-8f0f-4f6a-a69f-ed1001f8bd09.jpg
Jul 15, 2014 | HP Laserjet Cp2025n Printer
Alignment off on HP CP4005dn Color Printer
dear friend
how much life pending in image transfer belt
check first
Mar 27, 2014 | HP Color LaserJet CP4005dn Network Printer
Error instal supplies hp 2700n
make sure all the toners are installed correctly and that they are full. also make sure that the fuser and ITB is in working condition. you can also take the printer to any Hp service center for a skilled technician to have a look at the unit.
Nov 07, 2013 | HP Color LaserJet CP4005dn Network Printer
I have a lot of white stripes on the left side of the page 25% of the page only on yellow. If I change place of the toners so cyan toner is on the yellow toners place it will happen on the cyan color. So...
First of all it's really not a good idea to swap color positions. However sounds like a transfer belt problem. Try getting a proprietry printer cleaning sheet. This is like a standard size paper sheet that actuall has cleaning properties. Run that through a couple of times and see if that solves the problem. If not you may be looking at a new transfer belt unit.
Oct 28, 2013 | HP Color LaserJet CP4005dn Network Printer
Dots on prints
It depends on what kind of dots you have, but mostly are caused by toner dripping.
Check what color dots are, and change that toner cartridge.
Another posibility are: Bad fuser or bad transfer belt.....If dots are easily removed by your hand, is the fuser. If dots are colorless, could by the transfer them
Sep 14, 2013 | HP CP3525N Color LaserJet Printer
HP 3550 printer: copies are coming out with faint images of previous printing jobs
Ghosting is caused by a failing transfer belt assembly. The transfer belt is how the printer moves the image from the colored toner cartridges to the paper. The surface has a special organic that allows the toner to be picked up and is transferred to the paper but when it gets worn down some of the toner stays on the transfer belt which causes the ghosting of the previous image. The transfer belt assembly is user replaceable and looks just like a big toner cartridge. You can get them from Office Depot or Amazon.com as well as almost any place you can get the toner for the unit. Here is a link to Amazon.com
http://www.amazon.com/HP-Color-Laserjet-3500-3700TRANSFER/dp/B0001GKY7C/ref=sr_1_1?ie=UTF8&qid=1315341092&sr=8-1
I hope this helps, if so please rate my solution.
BuddyMc
Sep 06, 2011 | HP Color LaserJet 3500 Printer
Friends, I put a new transfer kit and laser toner cartridge to my HP Color LaserJet 8550n Printer and when I print, the paper go out completely in black. What could happen?
Put the original cartridges and transfer kit back in the printer.
Print to see if it prints ok. If it is ok, insert the cartridges one at a time, printing something after each replacement. Try the transfer belt last.
If all is ok, one of your replacements is bad. Repeat the swap outs as suggested above.
Jan 29, 2011 | HP Color LaserJet 8550n Printer
HP Color LaserJet 2600n Printing Problem!
franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Aug 25, 2008 | HP Color LaserJet 2600n Printer
you probably needt o change the transfer belt which is the "black roller film". you can try wipping it off with a dry lint free cloth.
May 16, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet CP4005dn Network Printer Logo
424 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
