You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at
www.cordlessrepair.com
