Procedure Cold Reset
1. Turn off the product.
2. Simultaneously press and hold the Cancel button and the right arrow button (> ), and then turn on
the product.
3. Wait until the message Permanent storage init. appears, and then release the Cancel and right
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Let me know if this works. it should bring the printer back to factory settings.
SOURCE: my printer hp m2727nf
I wrote a tip on how to address this situation. It is here.
That tip was written for a different model but the steps are the same.
Error
79
Software/drivers, Memory PCA's,
Font-Macro-Personality Cartridges, option I/O Cards. Defective toner cartridge
in the Laserjet 4 Plus only. Remove any accessories (font cartridges,
memory PCA's, SIMMs, etc.) plugged into the formatter card and try again. If
the problem persists and is application specific, verify proper setup with
application vendor.
Defective Formatter PCA - Replace with
known operational board and try again.
Firmware Update - The configuration page lists the firmware version of the
product. Depending on the model, a firmware DIMM may need replacing or a flash update. On flash-memory-based products,
you can update the firmware code by downloading the latest flash executable
file for the product and running the program according to the readme
instructions posted with the update file. If the firmware should become
corrupted or fail (usually because of an interruption when attempting to update
the firmware), the product will no longer function. In this case, a firmware
recovery DIMM is available.
Reseat DIMM, then Formatter - Replace or flash
DIMM then formatter
Can this also be?
