Relax my friend, you can use your PUK code to unlock blackberry curve 9300 password, just type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. That code will make your blackberry unlocked from your previous password so you can setup new password for your phone.
This lock code is something you would have chosen, their is no default code and no way to recover it. This is by design for security reasons. You have 10 attempts in total to guess if you don't remember the password. After 5 attempts the letters you type will no longer be hidden behind "*". After 10 attempts the phone will be wiped clean. All of your data will be lost. Hopefully you have been connecting your phone to your pc and doing a regular backup. If you have synchronization activated with your email accounts (done during initial setup of gmail or exchange type email accounts) you won't loose your contacts. Anything else that is on the internal memory of the phone will be lost.
SOURCE: I have a blackberry curve I had a security code
you just have to enter the password even if its wrong about ten times then it will restart itself and you can create a new password
www.usedcecllphoneshop.com
SOURCE: MY BLACKBERRY PHONE CURVE 9300 STROLL IS NOT WORKIN AFTER TRYIN TO UN LOCK WHAT CAN I DO?
Alice, read follow :
identifying problem : this is sound me hardware problem,on scroll area; Causes :normally this happen by water damage (because of wet finger touching), Solution :
Clean with alcohol the scroll area and keypad area on board, and let it dry for 4hours, it will start working.
Material need :
screw drivers tools for device, Brush,and alcohol.
Notes:
if you don't know how to assembly and dissembly the device search on you tube.com but if are you not able to do this at home, please don't try without supervision of technician,give some official repairer to fix for you.
