Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
I have a Toshiba 42H83. When adjusting the convergence The blue line on positon #8 (lower center) is diagonal. All the other positions are fine. We just moved so i wonder if that had anything to do with it. Any suggestions? Dean
David Duncan
  • 760 Answers
If you just moved it is very possible that you had some week solder break loose at your convergence IC. Reflow the solder on all pins and see if that does not fix your problem.
Posted on Jul 15, 2011
  • Anonymous Jul 15, 2011
    Thank you i'll check that out. Dean
Toshiba 42h83.... The blue convergence will not line up. The horizontal will but the vertical will only move so far. when touch focus starts the reds and greens are perfectly strait the blue vertical is...
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
How do i get the blue and red lines to line up
They are adjusted through the convergence control in the menu.If they do not adjust, the convergence IC's are bad and need to be replaced.
Call a good TV Tech.
Jul 30, 2009 | Toshiba 42H83 42" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 Touch Focus Problem
I just got finished repairing the same model . The convergence modules are bad cost of repair is 250.00 for a service center to fix. My advice would be call your local service center tell them what i told you bad convergence ic and ask them how much they charge,
thanks doctor video good luck since 1987
Jun 14, 2008 | Toshiba 42H83 42" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Convergence problem with Toshiba TV 42H83
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Aug 04, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
