Question about Euro-Pro Shark GI490 Iron
Cord has a short in it - Euro-Pro Shark GI490 Iron
Posted by ehatch on
  • Obertelli
    Obertelli Jul 15, 2011
    It's unclear what exactly you're asking here. The obvious answer is to replace the cord. Is there any reason why you can't do that simple task? If there is, then with all due respect, you need to get a knowledgeable friend or an electrician to do so for you as an incompetent repair will be very dangerous.
Ronald Rebulanan
    Sergeant:
  • 422 Answers
You'll have to remedy or better replace the cord. Just buy similar to hardware store and put it to your iron. It's simple to replace and you have to have a analog tester to be able to test the cord without plug-in to AC wall voltage.
Thanks for asking.
Posted on Jul 15, 2011
Love the euro pro but iron started to spark and cant seem to ooen it.
Ok, there is a short inside but the cord at the iron may be the problem. You need a CSA cord replacement if that is the case. Best idea is to scrap it in the blue box. If you are short of funds, try opening from the top and look at it as a learning experience. Oh with the plug not in the wall.
Mar 16, 2018 | Irons
Fix Rowena iron with retractable cord
I would contact a small appliance repair business near you, they can supply the needed cord and the repair for very little money I would think
Sep 23, 2016 | Irons
Electric cord is working sometimes
You have a short in electric cord. If you choose to replace cord be sure to replace the entire cord. Do not attempt to repair a damaged cord as this may present a fire hazard.
Jan 27, 2014 | Sunbeam Irons
Replace cord
yes you can change it or you can also take some repair.
Jan 19, 2014 | Panasonic NIA56NR NI-A56NR Iron
My iron trips the safety switch and causes a blackout of a third of the house. Is there anywhere I can get it checked for free? I live in East Fremantle, Western Australia. It cost $130 about 12...
This must be easay if you have a multimeter to check, The power plug must have a clean continuity to the coils of the iron. It is possible that the cord is short and so the short seems to make the circuit trip. To confirm remove the main power cord from one end and check for short in the wire. If the mains and neutral shows a short with one wire taken off from the iron then the wire is short. If not the short is within the iron that can be checked in the similar manner.It can also be a very minor problem of a wire sticking to short within in the control.
There are many good brands, Philips, Rowenta,Black and Decker, Panasonic etc.. choose one which suits your need.
Jan 11, 2011 | Philips Irons
When i plugged the iron it wont start , i have to shake the plug up and down then it start and as soon as i leave the cord it goes back to shut down
You have a short in the cord.Go to ace hardware and get a replacement cord. remove the bad cord. And put the new one on. Your ready to iron.
Aug 10, 2009 | Irons
The cord on my professional Luxe has a short near the handle.
Take your iron to a hardware store and they should be able to guide you to the tool that you will need.
Feb 13, 2009 | Rowenta Professional DM890 Iron with Auto...
Power won't come on
You have a short in the cord. If you knew where the short was, you could possibly repair it. However, I would strongly suggest buying a new iron. An iron is an appliance that can burn your house down even when it's in GOOD working order. You should be able to buy a decent iron for around $30, and I would say the peace of mind alone would be worth it. Hope this helps,
Chad
Oct 08, 2008 | Rowenta Professional DE880 Iron
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Jun 27, 2008 | Conair Dry 'N Straight Hair Dryer and...
Euro-Pro Shark GI490 Iron Logo
134 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
