Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toner exhausted and replace toner how can solve this error without replace new cartridge
Anonymous
Level 3:
  • Samsung Master 32,281 Answers
  • Posted on Jul 15, 2011
Anonymous
Samsung Master
Level 3:
Answers
32281
Questions
Helped
7913046
Points
102259
When the toner cartridge is exhausted or empty then the printerwill not be able to print further documents or the prints will be very faint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Konika c 552 error code is 2a21 New release filur. How to solve
Here you go!
Konica Minolta bizhub C3350 Error Codes
Code
2A21
Description
Toner cartridge/C new release failure
The status with the new cartridge is not cleared after the new toner cartridge is set.
Causes
• Toner cartridge/C,M,Y,K • Printer control board (PRCB)
Remedy
1 Check the connector between toner cartridge-relay CN79-EXCB CN4 for proper connection and correct as necessary. - - 2 Clean the connection between the toner cartridge and the machine if dirty. - - 3 Reinstall the toner cartridge 4 Check the harness for proper connection and correct as necessary. - - 5 Check the connector between EXCB CN2-PRCB CN11 for proper connection and correct as necessary. - - 6 Replace the toner cartridge - - 7 Replace PRCB
Anthony
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
How to solve toner exausted problem through software
You cannot solve this problem with software. You need a new toner cartridge or a re-manufactured toner cartridge.
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Samsung ml2851nd toner exhausted error
My samsung printer scx 4300 toner exhausted replace toner error How to solve this problem?
Please open the following link:
http://skp.samsungcsportal.com/integrated/popup/TSGDetailPop.jsp?cdsite=in&seq=318
Then click on Error messages, Next, In Next Page, select Toners and click Next, then click on "Replace the toner cartridge" in next page and select Next..
Then follow these steps:
1. Turn the machine off, then wait a few minutes for the machine to cool.
2. Open the front cover.
3. Grasp the handles on the toner cartridge and pull to remove the cartridge from the machine.
4. Take a new toner cartridge out of its package. Don't use sharp objects, such as a knife or scissors, to open the toner cartridge package. You could damage the surface of the toner cartridge.
5. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge.
6. Remove the paper protecting the toner cartridge by pulling the packing tape.
7. Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the machine. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
8. Close the front cover. Make sure that the cover is securely closed.
2helpful
2answers
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
http://www.tronix.ro/toner-samsung-scx4300-p-9783.html
92helpful
7answers
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
6helpful
2answers
Toner exhasted error in samsung scx-4300 .how to re solve without new toner.
When toner exhausted error comes up, To prevent serious pollution or breakdown of printer, the printer stops printing.Replacing the toner cartridge with
another one will solve the problem. If you have another toner, not necessarily a new one, try to change it with the old one and then try it to print. if it persists, then you may need to get a new toner.
27helpful
6answers
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
