Normally when the cabinet is extremely hot it is an indication that the condenser grill is not getting enough airflow accross it to cool down the freon. Then could be because the condenser fan is not operating or the condenser grill is dirty or there is no front to back air flow.
So first thing you need to do is check and make sure the condenser fan is working (the one under your unit). If it isn't then replace the fan motor. If it is functional, then clean the condenser grill (the one underneath the unit) and if that is not the problem, then I would suggest you raise your frigerater up (put on a 2x4 or 4x4 (front to back) to increase air flow.
I have a refrigerator is my garage also, and was having similar issues until I raised my unit up, which also helped with keeping the condenser grill clean.
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
