I understand that your Frigidaire washer, model# GLWS1339CS, will not drain the water even if you program it to just drain. I also see that you just replaced the drain pump in your appliance. I suggest checking the drain hose to make sure it is not kinked or clogged. I would also check your home's drain system to make sure that it is not clogged either. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
This machine does not have a direct drive unit which is the one that has the coupler. The clutch assembly is located with the transmission on this unit. If you undo two screws at the bottom of the front panel then pull panel forward and off then you will see the transmission. It is right below the drum and kinda looks like a counter weight.
