Question about Magic Chef Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
Posted by daryel_turge on
Dan Webster
  • Magic Chef Master
  • 8,220 Answers
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 14, 2011
GORDON'S APPLIANCE SERVICE
  • 283 Answers
Replace the ignitor. They wear out after a few years. Its designed not to allow enough current to open the safety valve in situations where it doesnt glow brightly enough to ignite the gas.
Oven does not start
Your glow bar igniter is probably burnt out. If you don't smell gas when turning it on that is OK since the glow bar igniters have a built in safety not allowing the gas to open without ignition. I bought a replacement igniter off ebay and wired it myself. Medium to easy handyman fix. Cost was less then $20 off ebay, but would have been $85+ elsewhere.
Jan 29, 2011 | Kenmore 33169 Gas Single Oven
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
Oven will not heat past 100 degrees. Circuit breaker is not tripped. All other parts of the oven work fine.
Hello there:
It won't bake or even heat up correctly or If your oven won't bake, check these: Bake igniter Other causes Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
Jul 24, 2010 | GE JGRP17 Gas Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven takes 5 minutes to come on (ignite).
    Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
    Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
    No gas to oven
    Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
    Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
    Oven won't ignite but broiler does
    Bake igniter
    Other causes
    • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
    • The thermostat is defective.
    • The safety valve that prevents accidental gas flow is defective.
    • The selector switch is defective.
    Aug 11, 2009 | Ovens
    Oven won't light, even with ignitor getting red
    Bake igniter
    Other causes
    May 23, 2009 | Magic Chef 9122 Gas Single Oven
    Oven burner doesnt light
    Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
    Hope this helps and good luck.
    May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
    No flame
    when this happens it is usually because of a faulty flame/gas safety valve.
    Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
    Ovens Logo
    323 people viewed this question
    Top Magic Chef Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
