I have three sets of audiovox infrared headphones (wireless) that have the covers missing from the battery compartment. Do you sell the battery covers separately from the headphones?
I found the manual linked on the Amazon Product Page for the headsets. You can download it here: http://www.amazon.com/Audiovox-Advent-Wireless-Headphones-Silver/dp/B00000J1GA
The owners manual does not say much about the infrared, however you cannot use the vehicle sound system and the infrared at the same time. When the player is in use and the raidio is off, you should see red lights (4) in the black plastic above the screen. This indicates the infrared is transmitting. if still no sound thru the phones: R&R the phones. Amazon universal infrareds.
BATTERY INSTALLATION AND INFORMATION Your wireless headphone unit requires two rechargeable AAA batteries. Rechargeable batteries are uncharged when you purchase them. Before you can use the wireless headphones, the batteries must be charged for 16 hours. Follow these steps to install and charge the batteries. Installing the Rechargeable Batteries Take care to follow these steps to correctly install the batteries. 1. On the right headphone, locate the battery compartment (1). Use the finger depression on the compartment to turn the battery compartment cover counterclockwise to remove the cover. 2. Insert two AAA rechargeable batteries, carefully following the markings inside to ensure the batteries are inserted properly, with the + and - ends in the correct positions. 3. Replace the battery compartment cover. Charging the Rechargeable Batteries To recharge the headset unit, follow the directions below. Note: The cradle/transmitter on the WHP141 is not a recharging cradle, although you may place the headset in the cradle during recharging. Follow these steps to recharge the NiMH rechargeable batteries. 1. Make sure the ON/OFF switch (2), located on the right headphone, is in the OFF position. 2. Connect the AC/DC main power adapter to the DC IN power supply socket (11), located on the back of the cradle/transmitter. 3. Plug the adapter into an electrical outlet. 4. Connect the charging cable (10), located on the back of the cradle/transmitter to the recharging input (3), located on the right headphone. The headphones can either be placed in the cradle/transmitter or placed next to the unit. If the headphones are connected correctly, the charging LED indicator light on the cradle/transmitter (8) illuminate.
I have the original "Installation & Operation Instructions" for the W500 wireless headphone system.
Send me your e-mail address and I forward a scanned copy if you want so.
ebay?
most all infrared headphones are interchangeable just do a search and should find plenty of sources to buy from you dont need to get gm ones.I know audiovox works as i have used these on gm vehicles before
My set has an led that glows red when on...if batteries in correctly, and switch on...do you have a red "POWER" indicator. If yes, & still no sound, 1-does the other set work? 2- either side of prob set work? 3-VOLUME up all the way? Could be bad receiver/bad speaker(s) bad vol switch.
IF no POWER led on, then 1-bad batteries 2-bad power switch 3-broken internal power lead/wire.
Kids are rough on these things...any sign was dropped, or dunked in a coke? REMOVE ear cushions are screws if yur inclined.... sk
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
