Question about LG 37LH20 37 in. LCD HDTV
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if I use the the audio input there is no picture. I tried vga to hdmi and also no sound. Is there a solution?
Posted by belmarin on
tetherton
  • 3 Answers
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Posted on Jul 14, 2011
How to hook up VCR
Use Audio video cable from a VCR to TV input jacks. Select AVI mode from input box option of your TV. The second way is connect RF cable with VCR to RF jack of TV and auto search again your TV channels.
May 26, 2014 | Element Televison & Video
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
I'm trying to connect my mac to our lg tv. Visuals are fine, but the audio is not working. I'm using one of those belkin cables that has a white and red ouputs on one end and one for the headphone jack....
maybe the earphone plug on the MAC is not functional ...so try the one in the back ...the one for the speakers....if it is still not working ...just use a separate cable for the audio cause in this case the cable is not ok ...and just use a cable that has a 3.5 jack on one end to get signal from the audio output (no important is from headphones or the rear output) ..and in the other end to have a RCA plug just like the one fro audio ..
Here is an example for what kinda cable you need...(if you have some old cables you can make one by attaching a Jack 3.5 to an old RCA cable ..
http://www.amazon.co.uk/Belkin-3-5mm-Jack-Cable-White/dp/B0002AFT7M
Only that if you have only one RCA input on tv ..you only need a mono rca ..
Oct 23, 2010 | Computers & Internet
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
Pc 2 tv
You do not need a new sound card.
When you plug in the audio cable, can you still here sound coming from the computer speakers?
If so, you are likely using the wrong cable or plugging it into the wrong spot.
If not, you are likely plugging the cable into the wrong spot on your TV.
You can download the user manual here:
http://www.nodevice.com/user_manual/acer/notebooks/aspire_57105310.html , but typically your laptop will have a standard 3.55mm headphone jack on the front, side or back of the machine. From that jack, you should be able to run a cable like this [ http://www.mwave.com/mwave/SKUSearch_v3.asp?px=FO&scriteria=4322980 ] to your RCA in jack on your TV.
...it is possible your TV has more modern inputs like AVI, or HDMI and your laptop does too. Not knowing what sort of Samsung TV you have makes it difficult for me to speculate on what more modern connections might be better.
Nov 18, 2009 | Acer Aspire 5315 Notebook
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 09, 2009 | Acer Aspire 5100 Notebook
Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Jun 17, 2009 | Konka DLC-3211UT 32 in. LCD Television
Connection to tv from my pc to watch live action
Hi there.
The audio out or headphone jack is located at the front of the laptop and is coloured green.
Get a male to male mini stereo jack ( about 3 meters ) and you will be in business!!
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Acer Aspire 3610 Notebook
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
LG 37LH20 37 in. LCD HDTV Logo
512 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
