Question about HP LaserJet 5200tn Printer
Fuser error appears on screen and printer not printing
Posted by jeffreyr699 on
Saleem Baig
  • 283 Answers
Hi jeffrey
Normally the fuser assy. gets this problem
Try to remove the fuser assy. and clean the contacts of fuser and also in the printer and put back the fuser and push a little this will solve the problem.
BE CAREFUL AND TOUCH THE FUSER AFTER 15 MINS. have passed after turning off the printer.
Best of luck
Posted on Jul 14, 2011
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
50.4 fuser error 4015 laserjet
Faulty fuser..Remove back tray, take out & resit fuser assembly properly, observe that fuser lock are clicked or not,if you feel seated properly, switch on and shoot print command.. If its printing well then you are in in safe side, other wise replace fuser assembly just little bit expensive...
Feb 02, 2012 | HP Office Equipment & Supplies
When print command given to printer a screen appeared that fix unit error code E000 0000 every time .so give solution
good day sir.this a fuser temp error. These units are notorious for having fuser temp errors when there is dirty or unstable power, especially if the customer is running off a generator. the best way to fix this is to replace or rebuild the fuser assembly. goodluck!
Apr 25, 2011 | Office Equipment & Supplies
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
May 02, 2010 | HP LaserJet 2840 All-In-One Printer
50.2 Fuser error
You need to replace the fuser. Part number RM1-0013. Priced well on exchange at Seattle Platen. Contact is Dale 800-221-2388.
Jun 20, 2008 | HP LaserJet 4200 Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Engine Fuser Error
Engine Fuser Error appears on the display.
you must change your heat termostat
Jan 09, 2008 | Samsung ML-2550 Laser Printer
925.01 service fuser error
Hi The Fuser has failed meaning the temp of the fuser is to high or to low. In order to fix this error you can try powering down the printer for 10 to 15min and retry . I think though you will have to call for service or replace the fuser yourself!!! I hope I have helped.
Dec 06, 2007 | Lexmark T642 Laser Printer
HP LaserJet 5200tn Printer Logo
75 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
