Question about Samson C01U Consumer Microphone
I try connecting my co1u with fl studio 8 and I looked on YouTube how to connect a USB mic to fl studio it says go to options audio settings then I have to select my sound driver or device i click asio4all v2 then I click show asio panel I see my mic there with a x on it saying it's unavailable How do I fix this
Posted by f_moreno49 on
1 Related Answer
Anonymous
SOURCE: sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Posted on Apr 25, 2009
MD-1700 keyboard. How do I connect it via the USB port on the computer?
MIDI(Musical Instrument Digital Interface) is a standard data transfer system used exclusively for instrumentation. A side from amps 7 recording equipment many PCs, laptop & TVs have MIDI access built into them. If they can interface with a UBS connection it is more likely the exception rather than the standard. Below is a link to the users manual for your keyboard. Start reading on page 39.
http://www.manualslib.com/manual/593746/Radio-Shack-Md-1700.html?page=38#manual
Aug 05, 2015 | Image Line FL Studio 8 Fruity Edition Full...
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
STATIC FEEDBACK IN SYTRUS
in the audio settings put your latency buffer up more, the more underuns means your pc is trying to run harder than u let it. ( the more technical the somg the mor ticking/feedback, if u have buffer all the way up u needa better pc www.reverbnation.com/timcpatc for some music made with fl9
Feb 07, 2009 | Image Line FL Studio 8 XXL Full Version ...
Sound quality not good at all
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
How do you connect Audio Buddy to computer
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right. Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great. If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic. Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Dec 03, 2008 | M-Audio M Audio Audio Buddy Microphone
No good sound quality
ARE YOU RECORDING IN STEREO OR MONO
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Samson C01U Consumer Microphone Logo
424 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
