Coby MP300  MP3 Player  Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get a manual for your Coby mp3? I have turned the valume up and there is no music in the ear plugs.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Coby Master 102,366 Answers
  • Posted on Jul 14, 2011
Coby Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442685
Points
622693
You can download the manual from the manufacturer's web site at
http://www.cobyusa.com/files/manuals/MP300_MN.pdf
How do i download music to my coby mp3 player
You need to install the Coby Media Manager for your OS. Connect the player to your computer using the cable. Using the media manager, select the music you want to upload and follow the prompts.
http://www.manualslib.com/manual/29587/Coby-Mp601.html
1helpful
Can I use Coby MP305 4GB MP3 player with iTunes on my Mac?
You cant synchronize with ITUNES to a Coby MP3 player. Itunes will not recognize the device. Also, Itunes are AAC format which this unit doesn't recognize.
If you have MAC. plug unit into computer, it should show up as NO NAME on your desktop, you wuold have to drag/drop your MP3 file to this location.
If your interested in converting ITUNES to MP3, here is how you could do it on ITUNES "this does not work for purchased music" -
http://support.apple.com/kb/ht1550
Can't get music on coby
Thats probably because your music is protected Windows Media Audio files, try to sync an Mp3 file, this unit only reads MP3 or unprotected Windows Media Audio files.
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
How do you download music to my coby mp3?
Coby MP-C7085, manual in pdf format:
manual
How to convert and transfer music, video read this guide in pdf format:
setup guide
Coby support for all devices on this site:
http://www.cobyusa.com/?p=support
I dont know how to use my coby mp550 mp3 player
Read. The. Manual. I'm sorry if this sounds rude, but it really should go without saying. If you've lost the manual, Look for it at the Manufacturer's Website.
But essentially (and generically): To turn on: Press (and maybe hold down) Power Button (sometimes play button) until turns on. Ditto to turn off. To Charge: Plug it into the Computer (Make sure the computer is on). To sync Music. Plug it into the side of the computer, open WMP. Look for device in Library. Drag songs/playlist across.
And in future. Read. The. Manual. Thank You.
Coby 1GB
my mp3 player will not turn off so can some one please help me .....
Voice problems
i had the same problem and what was wrong with it was that the peice where u plug ur ear phone into it`s broken so what i would do is take it back and get a new one
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
