Question about Canon ImageClass MF6540 Copier
Prints are blurry when fed through the top tray. I have cleaned the glass plate and prints still are blurry
Posted by catalinamedi on
Robert Pavelski
  • 84 Answers
Might be a problem with drum or corona wires
Posted on Jul 14, 2011
MX522 will not print when doc's are fed in using ADF. A blank page is ejected.
Are you feeding the page through upside down?
Most ADF Units require the page to be writing side up as they loop over the scanner and feed out with the text facing down.
Check the ADF Tray as it will have a picture showing how the pages are meant to be placed to be fed through the ADF.
Sep 11, 2014 | Office Equipment & Supplies
Bizhub C652 has horizontal lines.
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or bink lines. This is a brand new c452.Scan to PC is ok, print its ok only copy. Lines are vertical.ea2265a7-6bf2-4ab0-abb0-94d103145c4c.jpeg
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Like many other people I have a vertical line down the copy, using the document feeder, not the plate glass. on my HP officejet J5780 3 in one. Your advice is to clean the small glass plate. I look...
I dont have a picture at the moment but if you lift the document feeder up to expose the large plate glass, the small plate glass is normally situated at the extreme left hand side of the large plate glass.
May 29, 2011 | HP Officejet J5780 All-In-One InkJet...
When I copy there are black lines across the page. I changed out the cartridge for a new one, but it still makes the lines.
Lift the copy bed cover and locate the **** glass (it is about 1" wide and sits on the left of the large glass)
Use a microfiber cloth, and a bit of water, and remove the debris from this **** glass. Make sure it is clean, then clean the white bar on the underside of the top cover (It will sit on that **** glass)
take a blank piece of paper and copy it through the feeder, if you have lines on the page that prints, you need to look harder for a spec on that glass. a small dot will create a line on any document fed through the feeder. A dot on the large glass will print only the dot as the paper is not moving over it.
Jan 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
Prints fine,1/2 in black line down the side when we make a copy.
Try this (one of many troubleshoots)
There are TWO platens with the ADF models.
One is the obvious glass plate (bed). The other is a strip of glass that is almost an inch wide. This stip is where documents fed through the ADF is scanned. Chances are, this strip is dirty. Take a damp clean cloth and wipe it down. I use isopropyl (rubbing) alocohol and do a quick swipe to loosen ink, gunk, adhesives, etc. off of the glass and finish with a dry cloth.
Hope this helps!
Mar 02, 2010 | Epson Artisan 800 All-In-One InkJet...
I have a toshiba estudio 650, I came to work from the weekend today, and the unit prints stretchy text, and a little blurry... I print diag page and it prints good, I use the scanner to copy or scan, and...
It defiantly sounds to me like the optics are to blame, if you remove the platen glass you will be able to clean the optics very gently with a glass cleaner just to pull the dust particals off :)
Aug 18, 2009 | Toshiba 6560 Copier
Black line when aoto fed document prints
If you lift up or open the auto feed you should gain access to a small **** glass underneath the autofeeder. Clean that glass with alcohol or some other glass cleaner. That should clear this up.
If any debris get on that glass the result is dark lines caused when the page travels over that part of the glass. Hope this helps. Let me know.
Nov 25, 2008 | HP Office Equipment & Supplies
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Apr 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Hp officejet 4355 scanner problem
don't on prints..super clean scan glass, slit of glass where originals are fed.
Nov 21, 2007 | HP Officejet 4355 All-In-One InkJet...
Canon ImageClass MF6540 Copier Logo
192 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
