Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Cannot get clothes out meesage e30 what can I do?
Posted by stephen_s255 on
Anonymous
    Scholar:
  • 70 Answers
Hi, E30 indicates a fault in the motor circuit, unplug the appliance and take the top off. Either side of the motor you'll find a carbon brush holder. Disconnect the wire to the carbon brush and take the holder out. If worn or broken, replace with new ones.
Posted on Jul 14, 2011
Edgestar e30
E30 is a door locking failure. The unit attempted to lock the door several times without success. First, make sure your door is closed firmly. Check for anything that may be blocking the door latch. Check that the latch is aligned to the door lock. Unplug the unit for 30 minutes to reset the electronics. If the unit still does not lock, please contact Edgestar at 800-297-6076.
Dec 06, 2013 | EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer...
Code e30 error
Hi John, thank you for your inquiry!
If you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, and based on the symptoms you are describing it could potentially mean a number of things: a pressure sensor issue, defective wiring, faulty pump, and valve assembly problem and/or control board issue. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Thank you for allowing me to assist you in a small way.
Sep 15, 2013 | Frigidaire ATF6000ES Front Load Washer
Electrolux washing machine error code e30
Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Jul 25, 2013 | Electrolux Washing Machines
Cadillac Deville E30, What do i need to replace?
All you have to do with any codes are Google them
Cadillac OBD1 E30
DTC E30- IAC-Idle Speed Control Motor
Mar 23, 2013 | Cadillac DeVille Cars & Trucks
Am looking for the Text message settings,and can't find it on the phone because am sending a message which is not going through
this happens because the meesage centre no for your service provider is not automatically updated in your phone. call your service provider to get the message centre no and use this no as meesage centre no in your text message settings.
good luck
Sep 03, 2011 | HTC G1 Smartphone
Keep getting meesage "Main Motor
Hi Chris,
This Error Code indicated that the "main motor that drives the OPC, ITB, and Pick-up is faulty".
Troubleshooting the symptoms is quite technical but If you like it to fix it yourself, just give me your email add and I will send to you the copy of the service manual to guide you steps by steps. Instruction on how to dis-assemble the unit is to long to write here.
Jdvillanueva
May 13, 2011 | Samsung CLP-510 Laser Printer
Have new dell inspiron. got screen meesage
Try booting into safe mode (F8 on boot) and using some of the built in disc checking utilities, If that does not help you may have to do a "Repair instalation"
Google that for more information
Jul 21, 2010 | Dell Inspiron 530 Desktop Computer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
