Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
Error:0x07d54dd62005:lib_barracu - HP PSC 1610 All-in-One Printer, Scanner, Copier
Posted by gend_bua1981 on
1 Related Answer
Anonymous
SOURCE: Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Posted on Nov 07, 2007
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
1helpful
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
1helpful
Everytime I plug in my printer,error:0x07d54dd62005:1ib_rracu
first unplug the printer,
then uninstall the software.
Go to Hp.com and download the drivers/software from the web site.
install the drivers/software by following the prompts.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Event ID 11
Please perform a erase operation and check if the drive does it, If its not then go ahead and check the SCSI controller if you have a spare one replace it.
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
2answers
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
8helpful
2answers
Ben Johnson
Marvin
Marvin
