Hello
To disable the wake up function completely; Press [Bell Symbol] [Music Symbol] & press '1' of '2' repeatedly unti no wake mode ikon [1-bell symbol, 1 music symbol or 2-bell symbol 2 music symbol] shows on large display. I can't include these symbols with this site, as I give you the details of the symbols.
You can download the manual of your Clock from the following website.
static.highspeedbackbone.net/pdf/RC46_DOC_Manual.pdf
OK.
Testimonial: "Okn I just did it hopely it works Thanks a lot"
Tips:
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
You can select your CD wake track by the following procedures:
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Setting Wake Time
This unit allows two wake times to be set.
on the top of the unit to WAKE 1 or
WAKE 2 position.
respective wake time. The time
decrements or increments will follow
by a faster rate when you press and
you are setting the time.
when finished.
http://audiovox2.info/docs/common/RP5430/RP5430_OM.pdf
