My epson sx100 is not printing correctly. The colour is working fine, but in the black parts there are gaps in the printing (of about half a centimeter). It happens about every 3rd or 4th line of text. It is when the page moves further through the print that it skips printing the black ink. I have tried cleaning, realigning all the general solutions to no avail. Any suggestions?
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge. byee
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
