Question about Peavey Pv 2600 Power Amplifier
How do i connect this amp to my powered mixer ( behringer europower 500)
Posted by latinoslikem on
Fred Yearian
  • Peavey Master
  • 5,603 Answers
Using TRS (balanced audio interconnect cables) go from the main output on the top of the panel to your amp inputs. MAKE SURE the amp is powered from the same receptacle as the mixer to avoid ground bounce and possiblle damage to your units.
Posted on Jul 14, 2011
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Feb 12, 2014 | Behringer Europower Pmp5000 Powered Mixer...
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
The cooling fan on the behringer 500 doesn't work. The fan is good, but the 24Vdc isn't there.
The fan in this is throttled depending on three temperature sensors on heat sinks in the unit... Until the temp is up the voltage will be far less than 24 volts. Two sensors are on the power amp heat sink and another on one of the heatsinks with the IGBT's in the power supply. The fan will run slow and very quiet until unit warms.
Nov 28, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Peavey Pv 2600 Power Amplifier Logo
184 people viewed this question
Top Peavey Music Experts
rhodesworks
ray gallant
Are you a Peavey Music Expert? Answer questions, earn points and help others
