Question about Kodak EASYSHARE G610 Thermal Printer
Kodak Easyshare G610 printer dock; feeder stopped working so I wiped roller with damp cloth as recommended in the manual. I allowed over 12 hours drying time but photos are barely visible. The manual does not mention this problem so I am at a loss for what to next. Any ideas out there? Thanks.
Posted by bjsupastar on
  • bjsupastar Jul 15, 2011
    What should I do? I have no repair experience.
Christopher Ian Tecson
    Guru:
  • 610 Answers
Are you using a thermal paper when printing? If you are, then this most probably a problem printer head problem.
hope this helps.
Posted on Jul 14, 2011
  • Christopher Ian Tecson
    Christopher Ian Tecson Jul 15, 2011
    Click this link and choose your country of support.
    After choosing your country, you can either choose to chat, email or phone them.
    You can also visit a local technician shop to have your printer checked.
    Hope this helps.
I have a kodak g610 printer dock and the paper is not being taken into the printer correctly and the printer keeps sending a message to unplug for 10 seconds and try again, any ideas
-Try to Unplug power cable for 10secs
-Remove paper try from the printer
-Make sure you are using the extralife paper or the thermal paper that came from the cartridge
-before you put the paper tray on the printer clean first all the rollers of the printer using a clean cloth
-Now if your done put it back now the paper tray
-Plug the power cable back
-Then do a test print.
If these solutions did not solve the issue please call kodak toll free 1 800 235 6325 and have it repair. GudlucK
Nov 02, 2009 | Kodak EASYSHARE G610 Thermal Printer
The printer will not pull photo paper through and print the pictures.
Had same prob with G600, all i had to do to get it working again was to clean the rollers with a damp cloth to get it working again.
Oct 15, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
May 27, 2009 | Kodak Easyshare Printer G600 Thermo...
The dock doesn't grab the paper. and if i help it, it just jams up
I had the same problem. Kodak support advised to take a damp lint free cloth ( I used a white handkerchief ) and wipe clean the center roller that grabs the paper. You can rotate the roller manually until you're satisfied you've cleaned it all. I just wiped it right to left several times and all was ok again. I didn't see any residue at all on the handkerchief but there must have been something that was there. Anyway, I think this'll work for you also.
Now if I could only figure out why my printer dock plus is only printing the lower part of pictures even though I installed new ink cartridge. Kodak advised to tighten slack in cartridge. There was not any noticeable slack. Still a no go.
May 17, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Adaptors
Hello
You need "D-26 Adapter"
Compatibility of KODAK EASYSHARE Docks
Best regards,
Zizzler
Apr 22, 2009 | Kodak EASYSHARE G610 Thermal Printer
Paper Jam
are you using the right type of paper? also check to make sure there is no paper stuck in the back or the top rollers, make sure printer isn't dirty, if the rollers are dirty clean them with a damp cloth, reset the printer. if these simple Troubleshooting steps don't work you might have to call your warranty company if you have a warranty on the printer. also if there is paper stuck then get the paper out and reset the printer as i said before
Mar 27, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Help with my Kodak EasyShare G610 printer
Have you tried cleaning the paper feed rollers with a slightly damp, lint-free cloth? You'll have to remove the paper try first. If that doesn't work you may have to remove the ink cartridge and tighten the roller. I had to call the Kodak technical support to get help with this. Hope this helps.
Nov 01, 2008 | Kodak EASYSHARE G610 Thermal Printer
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
Mar 27, 2008 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE G610 Thermal Printer Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
