Let's deconstruct the question into its components.
Area of a square-shaped flower garden is 64 m2
Area = length x width
Square = length of each side of the rectangle is the same
Side x Side = 64
side ^ 2 = 64
side = sqrt (64)
side = 8
Length of the side of the walk 8 + 1.5 + 1.5 = 11
Area = 11 x 11
= 121 m2
Good luck,
Paul
Area is 90.25 m2
SOURCE: The zigzag stitch will adjust width but not length
If it's a mechanical Bernina, it could be some of the lever mechanics have seized from old, dry oil. You can try liquid Tri-Flow Synthetic Oil--a couple drops where metal rubs on metal to see if it loosens things up. Applying hot air from a handheld hairdryer will help speed it up. The other possible alternative is that something is no longer attached to the knob/lever.
If it is a computerized Bernina, you should probably take it for service.
