SOURCE: MY LG DLE5977 Electric Dryer will not power on
Check the junction connection behind the dryer where the power cord and terminal block to make sure that the screws are tight. Then use a volt meter to check for voltage. The 2 outside wires should be hot leads and the center is neutral. Check hot to hot and you should get 240 volts. Check hot to neutral and you should get 120 volts. If you get those voltage readings, then you have a control board malfunction and needs to be replaced. There is no reset switch within the dryer for the control board.
SOURCE: LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
SOURCE: LG 250 Volt, 18000 btu window air conditioner.
Take cover off of electrical compartment, locate power on off switch, see if you have proper voltage before and after switch, if power is present locate thermostat, check the same way, also look for burnt wiring, Good luck.
SOURCE: My LG tromm wm2277hw front loader just turned off,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component.
PAGE 22
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
