Airflow around the condenser grill is very important. So you should take off the front grill and vacuum out that area the best you can.
Since this is a gradual warming trend you might have ice build up on your evaporator coils (usually means that defrost circuit malfuntioning). If you remove the food, shelves and back panel of your freezer section, you will be able to see if there is ice build up. If there is, unplug the unit and then use a hair dryer to melt the ice. Make sure you are ready to deal with the ice melt with either spongs and bucket or a wet/dry vac.
