Hi, It could be you have the volume set too high or the recording level was made too high. Turn down the volume or set up a stereo system to it. Good luck
Distorted sound issue can be occurred due to loose connection, cable or problem with source. Check if Distorted sound issue is related to any audio/video files or any particular TV channel. If it is related to any audio/video files or channels then check on any different channels or play different audio/video file which have good quality audio. More info on: https://www.samsung.com/in/support/tv-audio-video/television-distorted-sound-issue/
This may be he characteristic of mixing of the delayed when high distortion is present...
I would go to music store and compare... I tend to think this is the nature of the beast.
If you consider what the waveforms look like with distortion and then add them delayed... they limit out and when added there is a significant difference when adding or mixing waves that are delayed when squared compared to nice sine waves.
I would use the audio output of your netbook to supply signal to any external audio system so you can determine is it is an internal circuit problem or simply a failed speaker.
If the distortion is present in the sound output from the external system, then a circuit in the netbook has failed.
If it isn't audible in the external system, then a junky speaker has failed in the netbook.
What's the model number? Describe the distortion in some detail. Is it intermittent? Does it seem to affect anything else, like audio, when it's present?
Bill
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
