Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Posted on Jul 14, 2011
I need a new sink basket for my In Sink Erator, Model 5-81. Where can I get just the sink basket?
A
Anonymous
Disposal sink basket is not sold separately.
Go to local hardware and home center for returned defective disposal and then see if they will sell the basket assembly.
Be sure to get all the parts. Parts are generally universal, but the clip-on ring is sometimes missing and the old one might fit or not.
Contact insinkerator, and see if they have a box of spare parts at their factory in China:
http://www.insinkerator.com/service/index.shtml
HOW TO FIX MY LEAKY SINK STRAINER THATS CONNECTED TO A BADGER 5 1/2 HP IN-SINK-ERATOR THANKS FOR ANY HELP REALLY APPRECIATED
You have to take it apart and re-apply plumber's putty ... some specialize sink materials require different type of sealer, but stainless and porcelain use regular plumbers putty from hardware or home center.
I wrote EZ to follow steps that cover sink strainer basket leaking:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
There is a rubber washer between disposal and sink basket
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
1helpful
My in-sink-erator model 5-81 is just over 2 years old and is leaking from the sides whether it's running or not. Is there anything I can do or do I need to contact a professional>
Find out exactly where leak is coming from.
You say water is coming from the side... is that where the pipe connects? Then take apart pipe and reassemble pipe using instructions below, and use rectorseal on joints as described below..
Is water coming from where dishwasher connects to disposal? Then tighten the clamp.
Is water coming from top where disposal connects to sink? Run paper towel around top to check for moisture, and then use steps below to dissemble disposal and re-install same disposal.
Is water coming from a rusted hole in disposal. Then replace disposal using steps below:
Here are the disposal steps:
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
Apply good amount on washer just before pushing washer in place and attaching nut.
Add a comment
The gasket coming out of bottom of our sink erator was leaking and spewing. when we replace the washer before bolting on the gasket do we use plumbers putty?
Plumbers putty is for setting sink basket into sink.
I use rectoseal on all tubular washers and joints,
Smear it on thick and then assemble parts, and rectoseal ensures nothing will leak.
1helpful
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
That way we didn't have to change out sink basket.
2answers
My waste disposal unit wont turn on
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
I get a buttery flavor from the hot water
This is the first I have ever heard of that I would contact In Sink Erator with your model and serial numbers they have excellent customer service the number is on the sticker on the unit
2helpful
How do I change the rubber baffle that prevents
You need to remove it from under the sink and insert a new. Then reinstall. Not a real hard job if you are handy.
Kurt
3helpful
2answers
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 • Plumbing
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
