The RCA DCM425 is a cable modem. You need an Ethernet router to connect two devices to the wide area network provided by the modem. A router assigns I.P. (internet protocol) addresses. Your Dynex Ethernet hub is a switch which will enable you to share files between computers. It doesn't support directing traffic to and from the internet.
I wish that I had better news for you. You can get a router from many sources.
SOURCE: My connection fall
Please describe the leds in front of the modem which led lights or blinking ?
SOURCE: RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
SOURCE: rca dcm425
Try this site - they have RCA425 USB drivers posted
http://helpdesk.powergate.ca/index.php?id=19
SOURCE: DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
