SOURCE: inside leak
Here is some information on one full page, contaqct me if I can help you better. Choose the part that fits your situation and apply that to resolve the leaking Thanks, Sea Breeze
[email protected]
click below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
SOURCE: We have a Samsung side by side refrigerator that
Your "Condensor Fan Motor" has Failed! Hot Uncooled Gases being recycle around cabinet and front RAIL.
Tools Needed:
#2 Phillips Screw Driver
Steps:
Remvove lower service panel.
Look for a white plastic housing with creamy white fan blade.
This is the Condensor Fan, should be running if Compressor
next to it is running. Carefully give the fan a spin. If resitance to turning is felt, ORDER COMPLETE FAN ASSEMBLY and replace as a unit.(The fan grommets and covers are usually cooked) Call 1-800-Samsung order the part.
Once recieved:
UNPLUG FRIG>
The Fan Assembly "Slides into place"
To Remove Old, LOOK for release tab under assembly. Lift up tab and slide forward. You will have to gently tilt or move tubes out of the way BUT DONOT KINK OR DAMAGE REFRIGERANT TUBES!!!! UNplug harness by squeezing release and pull down.
Reverse your Steps to install new. Problem Solved!
What's it Worth If you DO IT Yourself? $200.00
Good Luck,
Seen IT B4
Your Welcome!
SOURCE: Water leaking from inside the freezer
This is something that I want you to work with me on as the model you have is complex and I will help if you want. Sounds as if the defrost drain is blocked and we need to do some things to insure that another issue is not taking place. I will give all information if you feel comfortable with me assisting you. I need the age of your fridge and your response as soon as possible Thanks, Sea Breeze
SOURCE: Please help. My refrigerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
a
SOURCE: My frig keeps icing over
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
