Question about Kenmore Elite 45986 Front Load Washer
Hi, the error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It costs about $99 to order from Sears although they are on backlog, or you can get it cheaper somewhere else. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected. Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires & 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor...
Posted on Jul 13, 2011
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Jan 19, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Jan 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Apr 22, 2010 | Kenmore 45087 Front Load Washer
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jul 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Dec 12, 2015 | Kenmore Elite 45986 Front Load Washer
Nov 19, 2015 | Kenmore Elite 45986 Front Load Washer
115 people viewed this question
