Question about New Bright Toys
Have a Cat Power Excavator #2193 old that needs new tire treds. Where can I get some?
Posted by amfurn on
3 Related Answers
Anonymous
SOURCE: looking for the switch to change from cat controls
Hey Rawhide.....have a Cat 315 myself and looking to do the SAME thing (just got it yesterday). Talk about confusing. I'm used to JD too, so if you hear.....please let me know and I'm going to try to find out from the guy I got it from 2morrow. I believe that it's a simple and easy fix but you never know. My email is [email protected] . Use Cat 315 in the header. Thanks (or anyone else too) Fran
Posted on Apr 04, 2010
fathi109
SOURCE: 320 Cat Excavator- engine idles, but does not
please let know the meaning of the code EOM
Posted on Jan 06, 2011
anton
320 D Excavator Bzp ..., start-up cannot on , there is
error 39: 590-9, please how to solve this problem, what should I check
Posted on Sep 19, 2013
Why does my boom on my 325 bob cat excavatoe drop quickly to the ground on it's own.
You need a new valve block assembly thats all inside the assembly is a restrictor valve to prevent this but on the old plant i worked on 40+ yrs ago it was allk mechanical and repairable but new stuff is predded together and not readly repairable like the old gear from my youth
Sep 27, 2014 | Cars & Trucks
Cat excavator
please finish the question but taking a guess at it its probably a check vale has gone out most liklely check valves seem to go out easy on cat excavator it can be fixed in the field or hydralics low on fluid replace. look for leaks this is just taking a guess with unfinished question
Sep 01, 2014 | Garden
Bouncing at higher speed
It has regular shocks on the front.
Sep 15, 2012 | 1992 Lincoln Town Car
2002 elantra squeals on turing steering wheel on either side then disapper on returning back.
your belt is most likely slipping or your fluid is low or the beerings in the pump are going out..
Jan 24, 2011 | 2001 Hyundai Elantra
Looking for the switch to change from cat controls to john deere controls on a cat 315 excavator
Nov 02, 2009 | Kettler Caterpillar Excavator
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
Toys Logo
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
