Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Hi If the drain pump assembly is fine and the drain hose is in
correct position then check the control board, maybe the relay for the pump on
control board is bad and the board should be replaced. Hope this helps...please
post back for further assistance. Daniel
Posted on Jul 13, 2011
mso-fareast-font-family:"Times New Roman";mso-ansi-language:EN-US;mso-fareast-language:
EN-US;mso-bidi-language:AR-SA">You are right the issue is not the agitator. It can
be either a broken/bad impeller or the drain pump assembly. You can disassemble
top deck, neck ring, agitator and inner bowl and use a container to empty the
bowl. Check for any foreign objects by inspecting from above by removing
pump hood, cap and impeller and check for obstructed drain hose. Also check the
pump hood cap and impeller and the bolts securing the pump bracket are tight. Replace
what ever has gone bad.
Jul 17, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Jun 11, 2011 | Whirlpool Washing Machines
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Feb 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Jun 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Feb 05, 2018 | Whirlpool Ultimate Care II GSW9650LW Top...
Sep 19, 2017 | Whirlpool Ultimate Care II GSW9650LW Top...
170 people viewed this question
The model number is GSW9800PW2. The chain like noise is only during the spin cycle. The water will drain it just will not spin. I actually changed the agitator dogs and that isn't the issue.
I have a Whirlpool Ultimate Care II top load washer product number GSW9800PW2. During the spin cycle the agitator does not turn and I get a loud chain like ringing noise. I changed the agitator dogs and that did not work. It is not the drain hose. Need help.
Thank you for the video. Very helpful to determine that this is beyond our scope. We plan to get a repair man and now we at least have some background on what needs to be done.
No worries. we decided on a washer repair person.
