Car Audio & Video Logo
Posted on Jul 13, 2011
I need to know about a pioneer deh435 wiring diagram...There is a blue (fused),red (acc,tag), and orange wire(s)what gets power, and what dosen't?
5 Related Answers
Anonymous
  • 363 Answers
  • Posted on Sep 21, 2007
SOURCE: Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Anonymous
  • 15 Answers
  • Posted on Jan 14, 2008
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Anonymous
  • 199 Answers
  • Posted on Feb 26, 2008
SOURCE: wiring diagram needed
http://www.service.pioneer-eur.com/peeservice/RegistrInstrMan.nsf/search?openform
hi you can download your manual from here
Mark
Blue ICE
Anonymous
  • 14 Answers
  • Posted on Dec 25, 2008
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Anonymous
  • Posted on Feb 06, 2009
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
1helpful
Wiring diagram
Rem- blue and white/ground-black/ red- battery + power/ orange-illumination/ you don't need phone/ your antenna should be a metal plug that goes in the back of the radio if not get and adapter , the acc is what tells it to turn on and off hook that to like your fuse box, to like your ignition switch or something thatturnsonwhenustartthcar
1helpful
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
2helpful
I need a FREE, Pioneer DEH P4500MP wiring diagram? Thanks
If this is your Model : http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P450MP.Support
Click on Download Owner Manual you'll have the Wiring Diagram in it !
Basic Wire are :
Yellow : Constant + 12V
Red : Acc + 12V
Black : - Ground
Orange : Dimmer Light
Blue : Electric Antenna
Blue/White : Remote Controller ( For Amplifier )
And 8 Wire for Speaker's each with a +/- wire ! Negative one's has a BLK line on it ! I Hope this Help you !
1helpful
I've lost the wiring diagram
I couldn't find a manual or wiring diagram for this model, but I am fairly sure this is it:
Yellow - Constant +12v (for memory retention)
Red - +12v Switched (ACC)
Black - Ground
Blue - Power Antenna
Orange - Illumination
Green - Left Speaker
White - Left Speaker
Purple - Right Speaker
Gray - Right Speaker
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
5helpful
2answers
P5000UB wiring diagram
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
1helpful
What is the orange wire for on the pioneer DEH-2800MP?
If you have a blue with white on it or a solid blue lead, I'm at a loss, however the manual even states that colors may change w/o notice. Best way to tell is to use a meter, black probe to ground and red probe to the orange. Put it on DC voltage then turn the ignition to acc. then turn on the deck, my hunch is that it's your amp remote turn on wire for an external amp or it can be used for a power antenna. Voltage should be 12.2-13.8dcv. Hope this helps
4helpful
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
35helpful
6answers
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
