Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
The dryer will run but wont put out heat. - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Posted by dfields140 on
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Posted on Jul 14, 2011
The timer will not advance and wont get hot
if the dryer is only getting 110v instead of 220v it will run but not heat check your power and breaker
Mar 23, 2014 | Crosley Replacement Clothes Dryer Thermal...
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
Runs no heat
Check for 220v will not heat with only 110v
Nov 24, 2013 | Roper REX4634KQ Electric Dryer
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
Wont heat
Looks like everythang you need to know is on page 19 of the LG MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2009 | LG DLE8377 Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
146 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
