SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
SOURCE: My phone is 5130 xpress music if i switch on the
Firstly flash the phone with latest software if not OK change LCD.Good luck.
SOURCE: I have 5130-c mobile phone
Remove battery and memory card, then replace battery after 15 minutes to switch on and reset to factory settings. If the phone does not boot up correctly then you will need to reinstall. Contact Nokia care for support.
SOURCE: when i switch on the
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
