It is possible that you have connected an adapter with a higer voltage or one with a wrong Polarity. In both the cases it is possible that the front end of the player has damaged components.
In some cases there is a possibility of the ZENER which is the protection in the input circuit that could have burned and saved the cicuit as it is normally connected to protect in parallel.
SO you need to check this out , also the short can burn up a fusible resistor or fuse and so could save the circuit. Use a mulimeter to check this section of the circuit. If not there will be serious damage on the main board.
