Question about LG WM2701HV Washer
Recently, my LG WM2701HV washer has been malfunctioning. When I press the power button, it turns on and then shuts off immediately. I would have to hold the power button for at least a minute or 2 and play around with the knob until it decides to stay on. Not sure what is causing this. Anybody having any similar issue?
  • LG Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jul 13, 2011
  • Anonymous Jul 13, 2011
    To be more specific, there is no error code when the issue occurs. It happens randomly. One day the machine works with no problem and the next the error happens. After holding down the power button for a couple of minutes, the machine stays on and I'm able to select the cycle and start running. However, that method doesn't always work and I end up having to repeat the process multiple times. At this point, I suspect it is the control board.
6ya staff
SOURCE:
Good mornin i jst wanne knw hw i can reset my lg front loader washine machine wd_80130fu itts malfunctioning plz help me
How to reset the washing machine:
  • Press POWER to turn the washer off.
  • Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
  • With the power disabled, press and hold the START/PAUSE button for 5 seconds.
  • Plug the washer back in, or turn the circuit breaker back on.
but most likely there is some other problem with the machine are you getting any error codes
Feb 16, 2018 | LG Cell Phones
No power but a de code when I spin drum
DE error code shows that there is a problem with the door latch assembly. If this latch switch does not work, the machine will not turn on.
Check the continuity of the door switch with a multimeter on OHMS.
Apr 26, 2015 | LG WM2701HV Washer
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
My LG wm2701hv washer will only turn on if I disconnect for 20 seconds and reconnect. Once the load finishes I have to do the same thing all over again. Any ideas?
try holding in the power button for 10-15 seconds while unplugged, if that does not reset, try the same just after plugging back in. good luck.
Mar 30, 2015 | LG WM2701HV Washer
I have a LG WM2701HV it is a year old and sometimes the washer is not turing on and doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker. Help!!
Hi Robert.
If the washer is occasionally not starting there may be an inlet problem or the door switch may be defective.
Most LG washers display error IE (inlet) or DE (door) if the problem is detected. In some case the washer simply does not start.
Check that there is pressure from the house.
If machine does not fill the inlet valve must be tested. The resistance across valve's terminals must be between 0.8 and 1.2 KOhms
The valve must get 120VAC in first part of the cycle. Testing must be done by a trained person.
If the problem is intermittent the problem is more likely the door switch.
The door switch assembly is held by two screw. The door lock must click once or twice when the start/pause button is pressed to start the cycle.
The door switch can be tested reading impedance across its contacts. The reading must change between infinity and zero when the door is opened and closed.
In some occasion overloading may result in the washer not starting. Check if the problem happens in coincidence with overloading.
Dec 28, 2011 | LG WM2701HV Washer
I have a LG WM2701HV it is less than a year old and sometimes the washer turns on and other times it doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker is...
How much soap are yall using? The washer is supposed to wash with less water. Too much soap causes problemas. Less than a year? Look for items in the filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2011 | LG WM2701HV Washer
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
LG WM2701HV Washer Logo
284 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
