Mach Speed TRIO Onyx MP3 Player Logo
Question about Mach Speed TRIO Onyx MP3 Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
Posted by tigecook on
Anonymous
  • 32,281 Answers
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Jul 13, 2011
Won't charge when plugged in to USB
Often the problem is the USB cable or the plug.
Make sure the USB cable is plugged in firmly, all the way on both ends. If it still does not charge, try using a different USB port on the computer or laptop. If that fails to solve the problem then get a new USB cable.
If none of the above solves your problem then your device is defective.
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • 0helpful
    How dont know how to charge my mp3 player
    Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
    The battery is not charging
    You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
    Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
    I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
    SanDisk Mp3 Player Frozen
    2helpful
    The unit is dead. it does not switch on despite plugging in usb. i tried to reset as well but it is simply put 'dead'.
    It may be fully discharged, and you may be plugging it into a low-power USB port. Try plugging it into a USB port on the back panel of a desktop PC. Or, try charging it with an AC-to-USB adapter (plugged into wall socket).
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    1helpful
    2answers
    My touchscreen mp4 player wont turn on
    try charging it for 2-3 hours and then try if not working after that maybe the swich is not working
    Ilo mp3 player won't turn on
    Ok, SOME MP3/4 Players indeed charge from the USB port, albeit slowly... usually tho there comes a charger that plugs into the "Mains" and then plugs into the USB socket on the Player.. Sometimes if the Battery goes really "Flat" the USB port is unable to supplu enough "Current" sucessfully charge it up. (Hence the need for wall charger) IF it was entirely Via USB it would take many hours, I would at least think overnite. Hope that hepls.
    Top Mach Speed Audio Players & Recorders Experts
    Steven Wander
    Steven Wander
     Mike M
    Mike M
    Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
