HP Photosmart M447 Digital Camera Logo
Posted on Jul 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear the memory in my M447 camera and/or upload the pictures on my computer
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • HP Master 102,366 Answers
  • Posted on Jul 13, 2011
HP Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428306
Points
622693
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
After downloading your pictures, put the memory card back into the camera and format it. This will clear the card and prepare it for further use. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted recently.
I cant take picture just see them
The camera does not take a picture when I press the Shutter button.
• Press the Shutter button all the way down.
• Make sure you are in Picture Capture.
• The memory card or internal memory may be full. Transfer images from the camera to your computer, then format the internal memory or the memory card. Or replace the card with a new one.
• The camera may be processing. Wait a few seconds for the camera to finish processing the last image before taking another picture.
If this dont solve it, send us additional details in your description.
Don't know how to download picture from camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
How to upload my pictures on the memory stick of my camera from my computer
for this ,use a MEMORY CARD READER . Insert the memory stick into the Memory Card Reader and connect the reader via the USB jack/port to the computer.Go to "my computer",select the M CARD READER which may be indicated as "Removable disk "F". Meanwhile select the pictures to b uploaded and right click the mouse to select ,"Move to"--removable disk "F" when all pictures are uploaded ,remove memory stick and insert in camera to see the pics .
How do you upload pictures on the internal memory?
If you normally upload your pictures by connecting via the USB port, remove the memory stick before connecting the camera to the computer. If you normally upload your pictures by putting the memory stick into a card reader, use the camera's memory stick tool to copy the pictures from internal memory to memory stick.
I HAVE A HP M447 THE PICTURE SCREEN IS BLACK
remove back cover, and re-secure your ribbon cable
3helpful
My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
The memory card
its usually an open slot on the camera visable to the naked eye,
if not, its a slot by the battery behind the battery cover.
hope this helps
Problem Uploading pictures
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Help, I can't upload my pic's to my computer, I am using a port that worked
If you have a SD card, or any other in fact, you can get a card reader/writer at most electronics stores. This will enable you to use a card reader instead of using the camera to upload pictures.
I use a card reader all the time, and never (almost never) use a usb connecting cable to the camera to upload the pictures.
One problem which can arise is that the camera may have internal pictures taken with no card. If this is the case, you can in most cameras, copy from the internal memory to the memory card. I realize that there are digital cameras which have no way to record to internal memory, only on the memory card whether that is a SD or some other kind.
As to your direct problem. Try to reset ALL in the internal menu.
My m447 hp photosmart...
Try copying your pictures to your hard drive and delelting the pictures off your camera. See if an empty memory card will change things.
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
