Dryers Logo
A
Anonymous Posted on Jul 13, 2011
The remote just stopped working and it is not the battery. I was told that the code in the remote is not reading the code in the receiver, but I can't get to the receiver to sync them. Would a universal remote work?
Anonymous
Level 2:
Sergeant:
  • Expert 422 Answers
  • Posted on Jul 13, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
422
Questions
0
Helped
104074
Points
985
Your fan has problem on its control board and not on remote transmitter control. Thermal fuse is blown inside its motor to protect the windings. Check the control board, crystal oscillator failed, micro-controller failure. A universal remote control will not gonna control the fan.
Thanks for asking.
My Dstv receiver model 65 is not responding to dstv remote control model B4, what should I do?
If your DStv receiver is not responding to your remote control, here are a few troubleshooting steps you can try:
  1. Check the batteries: Make sure that the batteries in your remote control are fresh and properly inserted. Weak batteries can cause the remote control to stop working.
  2. Reset the remote control: You can try to reset your remote control by removing the batteries, pressing any button for 5 seconds, and then reinserting the batteries.
  3. Clean the remote control: Sometimes, dust or dirt on the remote control's buttons can interfere with its functionality. Clean the buttons with a dry cloth or a slightly damp cloth to remove any buildup.
  4. Reset the DStv receiver: Try resetting your DStv receiver by unplugging it from the power source, waiting for 30 seconds, and then plugging it back in.
  5. Re-pair the remote control: If none of the above steps work, you can try re-pairing your remote control with the DStv receiver. To do this, press and hold the "Shift" and "TV" buttons on the remote control for 5 seconds, then enter the 4-digit code that corresponds to your DStv receiver.
If none of these steps resolve the issue, you may need to replace your remote control or contact DStv customer support for further assistance.
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Both car remote controls stopped working
The receiver probably just needed resetting and reprogramming. I am surprised three are working - normally the receiver will only allow two.
Receiver
COULD BE A WEAK REMOTE BATTERY A BAD REMOTE OR A BAD RECEIVER.
YOU CAN BUY AN EXTERNAL UNIVERSAL RECEIVER. THAT CAN BE MOUNTED CLOSER TO THE DOOR AND IS CHEAPER THAN REPLACING THE CIRCUIT BOARD.
BUT REMEMBER, I HAVE SEEN A RV POWER INVERTER PARKED NEXT TO THE GARAGE STOP A NEW OPENER FROM WORKING AT A DISTANCE OF 5 FEET.
SO I ALWAYS SUGGEST TURNING OFF POWER TO EVERYTHING YOU CAN JUST AS A TEST.
HOPE THIS HELPS
2answers
Codes
my manual shows 0393 or 0985 or 0939
1helpful
Remote does not work
Remote stopped working - I bought a universal remote Phillips / Magnavox used a code in the 400 range and everything worked. Hope this helps.
[2] 811 dishnet receiver
you need to program one remote with a different code, power off or unplug one of the receivers. Go to the other receiver and hit the system info button at the receiver. Now read the remote code at the bottom of screen would be a number between 1 to 15. Program the remote for a different code than what it shows. Push and hold down the sat button on the remote and leave go light will blink, enter code say 14 and the pound key. You will see the light blink 3 times on the remote. Now that code is entered in the remote now with that system info screen up on the tv watch at bottom where code is and hit the record key on remote and you will see it change to 14. All done . now just plug back in your other receiver.
2answers
Remote Code
I had the same problem. In my case it was easy to spot. Thehe battery cover of the remote was removed by my little    girls and she was able to tinker with the dip switch inside the remote. So  i played with them. I gues the dafault is all switches up and it worked. Hope it it helps
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
