This looks like you have a convergence problem, very common.
I have start to finish step by step instructions for this repair in this set, they tell you everything you will need and HOW to do the repair.
If you can use a screwdriver and either you or someone you know can solder, repair will cost under 25 dollars in parts and take a hour or so to do and I will be available to assist you if you need help.
Before you rate this solution let me know if photos I attach look anything like your problem and if you have questions make a comment here.
SD TECH
no two sets will look exactly the same but you should be able to tell if your set has this type of problem.
