IMHO it doesn't matter if it is an Australian PSU. (Power Supply Unit)
The only thing that would change from country to country, is the AC electricity coming in.
Australia uses 220 Volts at 50 Hertz (Hertz stands for Cycles per Second)
Europe uses 220 Volts at 50 Hertz
USA uses 120 Volts at 60 Hertz
Japan uses 100 Volts at 50 Hertz
The PSU converts the AC electricity into DC electricity.
The DC voltage, and amperage is very small.
Now to the PSU and the Chenbro RM22300
Inside the chassis is a Chassis Management Board.
(It is a PCB
Printed Circuit Board)
Orient your view of the CMB (Chassis Management Board), with the blue dip switch to the bottom.
{Dip Switch is a rectangular blue block with 10 white dip switches }
To the right, and situated towards the bottom are two white Molex connectors.
(Actually they are each a 4-pin standard Peripheral power connector. Molex is a misnomer. It is the first company to produce a plug with this configuration. Sort of like calling an open-end adjustable wrench, a Crescent wrench)
This gives you more information on the 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
{The Red wire is 5 Volts DC
The Yellow wire is 12 Volts DC
The two Black wires are Ground wires.
Two D cell flashlight batteries produce 3 Volts DC }
There should be two 4-pin standard Peripheral power cables coming from the PSU.
They plug into the two white connectors mentioned above.
(The shape of the plug, and the connector on the CMB, will only allow the plug to be plugged in, in one direction)
There should also be a Purple cable.
The Purple cable plugs into JP1.
Looking at the CMB as stated above, there are two square looking connectors to the right of the board.
The one at the top is JP1.
(The one under JP1 is JM1)
I would also like you to have the User Manual.
Download it from Chenbro Support,
http://www.chenbro.com/corporatesite/service_download_result.php?type=pro&mk=30&sk=48
On this page left-click on the blue - DOWNLOAD - to the right of -
RM22300 - CMB User Manual for Windows - 899.8KB - 2010-07-13
This is a PDF file. {The computer you are using now has Adobe Reader on it, which uses PDF files}
After you click on the above link it may take up to 30 seconds before the first page will come up.
It may also take additional time for the file to fully download.
{Watch the download progress bar}
There is a way to save a copy of this file to your computer. If you are not aware of how to perform
this, and would like to, please post in a Comment.
{This way you will not have to download again.
You will also be able to burn a copy off to a CD, and have it for safekeeping.
You can also delete it from the computer you downloaded it on, and save Harddrive space }
Regards,
joecoolvette
